vigica c100s dead after update
  • tango
    • 1033
    hi guys
    i bought a c100s and it had problems with not loading kodi so tried to do an update
    booted to recovery and it looked like it was updating but it didnt
    then rebooted to recovery and tried again .... same thing
    rebooted to recovery and tried for third time the box then rebooted and didnt boot anymore
    no power light or anything
    now read alot of posts all over the net and found nothing to fix this
    even tried to use uart
    with uart i get this message using putty
    pll_times 4 : 1390/mnt/nfsroot/sandy.luo/jb-mr2-amlogic-2/uboot/arch/arm/cpu/aml_meson/m8/firmware/pll.cpll_init0x000000cf
    this just continues looping with the only part to change is the 1390/ counts up ie 1390, 1391, 1392 etc etc
    anyone know how to get this box working again?
    even tried to do the 29,30 short trick but still nothing
    cheers
  • gadget78
    • 84
    head over to freaktab website, they list a 'usbburning tool that can force a rom update
    • Technophobic
      • Mar 2016
      • 76
      I did something similar to my Minix X8 H Plus box and used the method described by gadget78 and managed to revive it. Mine was worse than yours as I stupidly left an image for another box on my flash drive which installed instead of the update I was intending. I thought, disaster, it was, but it now works as intended.
      • tango
        • 1033
        All sorted sort of now
        Read a lot about these boxes on a number of sites including freak tab etc
        Computer wouldn't see it for usbburntool to work
        After about 2 weeks and ordering a new k1-s2 (same box)
        Found another thread with another way to try and this worked
        Basically had to short pins 17and 18 for it to flash new image from sd card
        Now the image is on and working for sat but android is back to how it started off with nothing loading
        Kodi etc won't even start
        • Technophobic
          • Mar 2016
          • 76
          Glad it's sorted out. I found the USB cable used was important, the only USB cable that would work for me was the one that came with the unit, and I still had all the accessories in the box.
          I tried around five that I had handy and none would connect.
          • tango
            • 1033
            only thing i have wrong now is android side dont want to work
            so now looking into if i can maybe ftp from 1 box (working fine) to this 1 without having to install an ftp server to it
            as said nothing will install and run on the android side so kodi wont run or install etc
            • Technophobic
              • Mar 2016
              • 76
              I would try asking on a Kodi forum.
              Sent from my A 9 using Tapatalk
