I/O Link & distribution
  • PJD
    • Jan 2016
    • 70
    Is there a limit to how many magic eyes I can run from this?
    I have Sky HD box with I/O link connected, the I/O link is powered from a 240v supply
    I also have an openbox which has an RF modulator connected, the RF modulator is also powered from a 240v feed, both the RF modulator and the I/O Link are daisy chained together and sent upto the loft where there is a 5 way splitter with power pass (This is not powered) and is distributed to 3 TV's atm and works perfectly
    I want to add 2 more TV's to this set up, might I add I have magic eyes on all the TVs so I can change channels still on both the sky and openbox
    Is there a limit to how many magic eyes I can run? reason i ask is because I installed my 4th tv over the weekend and when i connected the magic eye it did not power up, i tried it on a separate tv that is already working and was fine, i can still watch both the boxes but am unable to change the channel because i do not seem to be getting any voltage down the coax
    Help please
  • staden321
    • Nov 2015
    • 73
    Are you running boxes of ***** ??
    • PJD
      • Jan 2016
      • 70
      boxes of what?
        Fill your boots mate http://www.ebay.co.uk/itm/Triax-TD-M...MAAOSwHPlWewac
        • PJD
          • Jan 2016
          • 70
          Originally posted by maca
            You would be better using a Powered Power pass amplifier in the loft
            • PJD
              • Jan 2016
              • 70
              To do this, would I need to disconnect the 240v supply's for both the I/O link and RF Modulator? or would it still be fine to leave connected?
                You can take the PSU off the I/O link as a powered Amp with DC pass will take care of distributing the signal and powering the magic eyes, your RF modulator for the openbox will still need its power
                • PJD
                  • Jan 2016
                  • 70
                  Okay thanks
                  Is this the kind of thing that will be needed?
                  http://www.ebay.co.uk/itm/1217764436...%3AMEBIDX%3AIT
                    Yes! thats the type your looking for
                    • PJD
                      • Jan 2016
                      • 70
                      http://www.ebay.co.uk/itm/LABGEAR-12...8AAOxyUylTTCw0
                      I think I will go for this instead, the other unit has F converters on in which means an extra joint, this comes with F connectors as standard, also the rest of my set-up has Labgear so is nice to keep it all the same I think
                      Do you think this would be okay?
                      • PJD
                        • Jan 2016
                        • 70
                        I ordered the second Amplifier in the end, works a treat.
                        Took a feed from the light switch and into a fused spur, fitted a 3a fuse, then fitted the 2 gang socket which powers the Masthead and Amplifier.
                        Cables are routed as follows....
                        Masthead to 12V feed in > Freeview out to Sky Box
                        I/O Link and RF modulator daisy chained together and feed up to loft and into UHF in
                        Then a feed down to each room with a tv which carries its own 9v feed to power the Magic eye, have Sky, Second Satelite box and Freeview on all TV's and the ability to control in each room
                        I tried to disconnect the power feed for the I/O link but lost the picture so just switched off the I/O link power supply from the actual secret menu inside the Sky box, this didnt seem to affect the picture.
                        All in all a good job, so thanks for your help I am very happy with it.
