zgemma s2 stuck on FLSH
  • dickypemb2344
    • Oct 2014
    • 10
    My zgemma s2 was stuck on boot I was sent a file to flash the box with to get It back up and running and the box has said FLSH on the front for nearly 4 hours when it said box should take 10 to 15 minutes to flash.
    Can some please advise the correct way to flash box.
    Also is there a way to factory reset box while it is stuck on boot.
    General
  • martin035
    • Apr 2014
    • 1308
    Sounds like you might have been sent a dodgy file, try flashing with this file;
    As Many members know, I updated to a H series Zgemma a while back, but DK member 'madness85' has an original Zgemma S and has developed his image for use by others on the forum, this image will work on a Zgemma S or 2S Openatv5.3 Backup Image with New improved SkyQ Skin, OTA update safe * AutoBuoquetsMaker autoupdate daily
    Unzip the file and place the 'Zgemma' folder on a usb stick drive then into the rear USB on the zgemma. When you power up the zgemma it will say 'USB' press the standby button it will the say 'FLSH' hopefully it will fix your box.
