recording issues
  • hatchet123
    • Mar 2016
    • 9
    recording issues
    hi,i have just upgraded from a skybox f5 to a zgemma h.2s,i have connected the two cables from the sky dish to the box as shown in the instructions given with the box,i have inserted a 64gb sandisk usb ,when i record a programme i get a black screen on other channels i try to watch ,the cables are ok, iam using vix and CCcam 2.3.0,the tuner settings are :-
    tuner a;bcm7346 (internal) (dvb-s2) advanced
    tunerb;avl6211(dvb-s2) not configured
    are these settings ok or am i set up wrong,thanks in advance,hatchet123
  • martin035
    • Apr 2014
    • 1308
    You need to change tuner B to 'Equal to tuner A' also ensure that you have initialised your 64gb Sandisk and have the correct record path.
    These setting are for openatv but you should find similar in the vix menus
    Menu-setup-system-storage devices-Initialisation, Select your drive and format it
    Reboot
    Menu-setup-recordin&timeshift-recording-default movie location /media/hdd/movies
    • hatchet123
      • Mar 2016
      • 9
      Thanks for your reply martin035,sorted now cheers🍻
