All images will have ts media in the plugin downloads
On the remote, menu-Plugins- Green button then scroll to extensions and press Ok then scroll to 'ts media' and press Ok to install
tks martin035 for your advice . i can programme the openbox v8s but when it comes to the zgemma h.2.s i am finding my way .
i used this youtube video to get my zgemma box up and running .
i have the channels up and running and can record what ever channel is needed . where i am having problems iis with the plugins . everybody seems to have their own favourite . iptv is okay but nearly every channels is polish . i would be happy just to get tsmedia up and running . i installed tsmedia but when you click on the movies section there is nothing in the folders .
another thing i find strange is the firmware for the box . in the youtube above he gives a link for the firmware he used . i downloaded it into a usb and straight away when i put it into the zgemma it booted up and then flashed away .
but when i download the zgemma firmware from other sites and put it into the back of the box and turn it on i just get boot then usb . nothing is flashed .
lads i would be greatful for any help in getting tsmedia and kodidirect up and running . tks in advance
Regarding flashing are you formatting the usb and unzipping the downloaded folder?
Then you put the zgemma file on the usb. Always ensure it is correct one for your box.
Make sure box is switched off insert usb make sure usb is in rear and only one connected then switch on power.
kodidirect is found in extensions via plugins. Don't try and download this with ts media your box may play up with both loaded.
Where e2 boxes are concerned read twice till your sure what to do. hth
