How to remove Autobouquets E2 - Open ATV
  • tony_i
    • Oct 2008
    • 425
    I'm on Open ATV 5.3 on the zgemma H1.
    I installed Autobouquets E2 but can't seem to get rid of it now.
    It's neither in the list of plugins to install or remove - it's just there.
    Any idea how to remove?
  • martin035
    • Apr 2014
    • 1308
    Try Restarting your Zgemma post removing the plugin and see if it's still there. If it is, the safest and easiest way to get shot is to reflash a new fresh image, if you want to be brave you could try and FTP to /usr/lib/enigma2/python/Plugins/SystemPlugins and delete the 'autobouquetse2' folder, then restart your Zgemma, however, it could make your Zgemma unstable????
    • tony_i
      • Oct 2008
      • 425
      Thanks. I've restarted a few times but I can't even attempt to remove it from the 'Remove Plugins' because it's not there to remove.
      I'll have a go at removing the folder. Bit of a pain as I don't fancy starting again.
      • martin035
        • Apr 2014
        • 1308
        Just had a look on the plugins menu 'autobouquets' is an 'extension not a 'systemplugin' so have a look in this folder for it /usr/lib/enigma2/python/Plugins/Extensions
        Or you could try a Telnet command via your PC
        ipkg remove enigma2-plugin-extensions-autobouquets
          Restart GUI from the Shut down menu .
          • tony_i
            • Oct 2008
            • 425
            Deleted the folder and the offending plugin has gone. Rebooted fine so hopefully it'll remain stable.
            Thanks for your help.
