Zgemma star 2s TSpanel How to install it
  • thekings
    • Sep 2009
    • 68
    Hi hope someone can help me out by mistake I have deleted the ts panel of my zgemma star 2s box. And can't find how to get it back on checked on my box and no luck. Can someone please give me a guide or something on how to do it. I have filezilla on my computer just don't know which files to send or what to get. Thank u guys for your help
  • martin035
    • Apr 2014
    • 1308
    There you go, unzip then FTP to /tmp then install via the 'Install Local extensions' in your Software Mangament Menu
    • thekings
      • Sep 2009
      • 68
      hi thanks for that. but i am still having problems i am trying to send the file once i have unzipped it to that tmp. But when i have sent it i go into my box software management plugin and it cant find it it says error
      • thekings
        • Sep 2009
        • 68
        i have tried sending it to the box. And when i goto box it says no file or medium found. i have uploaded back to box that file in the right folder tmp
        • thekings
          • Sep 2009
          • 68
          THANKS for your help just sorted it out i had to copy the same name on the file into filezilla.
          • thekings
            • Sep 2009
            • 68
            Cant find ts panel
            i have installed ts panel 7.5 on my zgemma star 2s and now it doesnt show up on the main menu where will i find it guys on the box thanks
            • martin035
              • Apr 2014
              • 1308
              Try menu-Plugins hopefully you should see Tspanel there.
              • happy_highlander
                • 3535
                Did you reboot the box after install
                Sent from my SM-G935F using Tapatalk
                • thekings
                  • Sep 2009
                  • 68
                  Tryed it
                  hi mate i have tried it still nothing there also reseted the box still no luck. dont know where it could be
                    It's a ipk file in dcc click>>tools>>IPKG packages>>>upload packages from where you saved them .
                    • martin035
                      • Apr 2014
                      • 1308
                      Right I installed the TSpanel7.5 on to my zgemma running Openatv5.3 it produced the attached python error when entering the plugin menu, which to me either means 1. a dodgy .ipk file or 2. TSpanel7.5 isn't compatible with Openatv5.3 ,as TSpanel isn't available in the Github then my conclusion is, it isn't compatible. You could try a older version ie 7.4 and see if that works, good luck.
                      • wannabuy
                        • Oct 2012
                        • 18
                        bad file on open atv build
                          Tbh i'd swerve it. It can be a pain the arse
