hi downloaded the latest openvix but i cant get the plugins to download it says error any help please
zgemma 2s
vix team have stop the plugin feeds for the 'XP1000' series of receivers which according to them were been abused by clone boxes, the zgemma uses the XP1000 feeds.
To get around this either change to Openatv or source the plugins you require as .ipk files and install via the local extensions menu. -
If your USB drives flash openvix they will flash openatv, ensure you have the correct image, when downloaded and unzipped you should have a 'zgemma' folder inside that another folder called 'sh1' anything else and it's the wrong software. Also when flashing openatv the front display will say 'Boot' then ''USB' then you need to press the front power button it will then say 'FLSH' the zgemma will then install the image.
To find .ipk files just google the name of the plugin with .ipk at the end.Comment
