IPTV SERVER + Zgemma Star 2S - Important Question
  • boxcabo
    • Apr 2015
    Hello my friends.
    I have sa Zgemma Star 2S Enigma 2 with Openatv.
    I am going to use it to produce streaming to put in a Linux IPTV Server.
    My Internet is Vodafone Fiber 200mbps UP and DOWN.
    The big problem is i am unable to produce more than 7 streams out of the box, if i try to produce 1 more strem it gives me: "streaming error".
    I have checked the processor and ram load with the 7 streams and its about 5% of processor and 50mb of ram.
    Does anyone knows how to solve this issue or this is some sort of hardware limitation like LNB or Zgemma.
    Thanks a lot for your precious help
  • martin035
    • Apr 2014
    • 1308
    IIRC and I could be wrong it's the limitation of the tuners, I thought it was a max of 4 channels per tuner and only if those channels were on the same transponder.
    Any way around this issue well either add more USB tuners to zgemma or get a quad tuner box.
    • digicon
      • 8261
      Limitation of not only the tuners but the receiver as well its way too slow, your maxing out at 8 channels. A more viable option would be a Vu Solo4K with unicable LNB and the built in FBC tuners which would give you 16 tuners per input as well as another 8 via the plug and play 3rd tuner if you installed a Dual DVB-S2 tuner.
      so 40 tuners in total
      • boxcabo
        • Apr 2015
        Dear friends, you won?t beleive this.
        I have installed Ubuntu Server and TVHeadEnd in a Dual Core Computer with PCI Skystar HD2 Cards and i am able to make 20 Stream per Transponder per Tuner.
        Processor is 20% Load and RAM is 250MB Load out of 2GB.
        I was: WTF as just hapen XD
        How can this be?
        Cheers.
