zgemma H2
  • seamus dunne
    • Oct 2016
    • 16
    zgemma H2
    Hi,
    When i go into recorded programmes it tells me max space is 3900mb to record. Is that the setting in the box or is the usb stick not big enough and if so can i change usb or will i lose settings. Thanks.
  • martin035
    • Apr 2014
    • 1308
    Sounds like you need to setup your USB drive for recordings, what firmware are you using ie openatv or openvix?
    • seamus dunne
      • Oct 2016
      • 16
      I can record ok but only 3600 mb space then says error no space. How do i find out which firmware i am using. I have a 3.81gb usb in the back nothing in the front.
      • martin035
        • Apr 2014
        • 1308
        Forget the last. 3600 mb = 3.6 gb the .21 gb is used by the zgemma for swapfile, EPG and any backup images the zgemma makes. So there's nothing wrong with your setup, SD & HD records especially HD do use a lot of space as the recording format isn't very efficient. My advice get a larger hard drive or watch and delete.
        • seamus dunne
          • Oct 2016
          • 16
          Ok Martin thanks for help
