question on channel signal
  • gingeee85
    • Jan 2012
    • 197
    hi had my setup all sorted couple of years ago, but im now struggling to pick up 1 channel on 19.2, all others, 65-70 signal but one channel sport digital seem to be 50-0 making it impossible to watch, is there a way to fine tune these things? normall just use channel lists
  • P&D
    • 2686
    Just blind scan 19.2 see how many channels you get........your not to clear with your question....if its not been updated in the past few years
    there lies the answer
    • cactikid
      • 12017
      google " kingofsat " it lists all channels for all sats for all your needs
      • gingeee85
        • Jan 2012
        • 197
        sorry, yes update channel list the other day, ill try the blind scan method thanks
        • gingeee85
          • Jan 2012
          • 197
          right so after doing the scan i still only get a 55% signal and noticed most others are 65% on the same sat. im now guessing my sat has moved slighty in the wind or something. what is the best sat finder so i can try realign dish?
          • DOUGALMCD
            • May 2011
            • 3229
            Unless your fitting them for a living the cheapest on bay will do. If your dish was close to window you could look at tv with satfinder on box telling you strength of signal so you could see it move up or down. Either way your dish is only needing moved mm up or down or sideways. hth
            • P&D
              • 2686
              @ the Op......you don't say what box/system your on
              If an Engima 2 system ........get your phone....and download from google play a sat finder
              Much cheaper.........FREE
