Zegemma h2s
  • Anth1
    • Apr 2015
    • 50
    Zegemma h2s
    I have 2 strange faults with my box
    1 keeps loosing epg and pause. Could this be that I only have 16 gb USB stick ? If I initialise the USB it seems to work.
    2 if I leave a terristial channel on for a few hours then change channel to a premium channel the box will freeze for about a minute however if I go onto softcam settings and restart it immediately comes on.
    its running vix what is this?
    could the box need new firmware were can I learn how to do this?
    many thanks
  • DOUGALMCD
    • May 2011
    • 3229
    So your box is on timeshift and thus you will need a larger drive.
    • Anth1
      • Apr 2015
      • 50
      Will a larger drive fix both faults?
      Would one of these USB 1 terabyte drives work could the box power it?
      Thanks for your help
      • Anth1
        • Apr 2015
        • 50
        Bump anyone?
        • jovie
          • Oct 2008
          • 100
          change your os to openatv your using the unsupported image file regards jovie
          • Anth1
            • Apr 2015
            • 50
            How easy is this to do?
            • jovie
              • Oct 2008
              • 100
              just download latest image from openatv for your box open it make sure its for your box and load it on a usb stick regards jovie
              all the information to run your box is on this forum just search for it you will find everything you need jovie
              • Hadron
                • 2102
                If you look at this thread in the sticky threads above, it will tell you everything you need to know, including a ready to use backup image:-
                This Backup Image is for the Newer H series of Zgemma Satellite receivers, it will work on the H.S and H.2s and confirmed working on the H.2H by Hadron @post #116 (requires additional setup for cable see post #119) but hasn't been tested on the H5 Openatv5.3 Backup Image with New improved Sky Skin, OTA update safe ?
                • Anth1
                  • Apr 2015
                  • 50
                  Thanks il take a look at this will this be everything including epg. ? No doubt this will wipe everything including lines?
                  • Hadron
                    • 2102
                    Yep. Includes EPG & bouquets.
                    It will overwrite everything that was on the box previously, but entering the "part that we cannot discuss" is incredibly easy. No need to ftp, just put it on a memory stick. Press a couple of buttons on the remote & you're done!
                    • Anth1
                      • Apr 2015
                      • 50
                      I don't have it can I get it from the box??
                      • Hadron
                        • 2102
                        Yep. I'm not sure where it would be in a Vix image though. It might be best to google it, as we cannot discuss this topic. You will need to transfer it using ftp.
                        • DOUGALMCD
                          • May 2011
                          • 3229
                          In the world of E2 I would suggest that you do a full back up of everything from box to usb before you start flashing new stuff. You can then save that to desktop in case it you have to re use it.
