zgemma s2 openvpn
  • madness85
    • Dec 2015
    • 38
    zgemma s2 openvpn
    Hi all,
    I installed open vpn and set it up, activated all seems well I've checked ip and itsee using my server ip, but when I reboot the box it sticks at 49 on boot anybody know what's going on?
  • martin035
    • Apr 2014
    • 1308
    If the box boots OK without the open vpn plugin then it sounds like the plugin is causing the problems, if using Openatv try doing a software update first before installing the Open vpn plugin and see if that makes a difference, if you're using a differnce firmware then ensure it's fully upto date.
    Don't forget to Backup all important files first
    • madness85
      • Dec 2015
      • 38
      Thanks for your reply I did an update and it's working, sadly the update did kinda break everything 212 updates I was using your image.
