using a diseqc switch on a zgemma box
    hi can a diseqc switch be used on a zgemma box.. if so how do i go about it have been at it for a while with no luck.. currently using 28.2 and 13.0 on it
    It most certainly can:
    Configuration Mode: Simple
    Mode: Diseqc A/B
    Then just define which port A or B has which satellite linked to it or choose auto for the image to choose the correct configuration
    • shankill2012
      • Feb 2010
      • 285
      I use a 10 way DISEqc switch on my zgemma H1 without problem, 10 satellites using "advanced " tuner settings with LNB's numbered 1 - 9 , DISEqc 1.2 , DISEqc 1.1 command ( same as numbered LNB )
