Motorised Zgemma H2s set-up.
  • spinfisher
    • Aug 2014
    • 5
    Hi guys,could someone please walk me thru box settings on Zgemma H2S? Dish and motor are up,got my longitude and latitude,and channel lists loaded.cheers Matt.
  • P&D
    • 2686
    Not to sound stupid......but are you asking how to input your long/lat & channel list on the box ?
    If yes thats the easy part ......who set the dish up & what alignment did you start with due south ? 28.2? ect.......
    Who channel list are you using ?
    Long/lat will be setup/tuner congfig
    channel list needs to be uploaded with VCC or Dreamboxedit or other software that does the same thing
    Matt you should of bought a H2H......have you not read whats happening on 28.2.......http://www.digital-kaos.co.uk/forums...-end-maybe-not
      You can still get those channels on other sats P mate .
      • spinfisher
        • Aug 2014
        • 5
        Thanks for the reply,I don't have cable in my area yet.I set up the dish,loaded a channel lists from the boxes plugins.I have inputted my latitude and longitude,just not sure what to do next.I have spent hrs on google researching this.Dish has been sat stationary on 28.2 for months since "upgrading" from diy triple lnb set-up, which gave me 28.2,13 and 19.
        • P&D
          • 2686
          Have look in here i used this when i set mine up.....http://www.digital-kaos.co.uk/forums...motorised-dish
          • smurph
            • Dec 2013
            • 31
            I have similar questions, I have an existing setup that used a protek box, and now have added a zgemma h.2s.
            So i don't need to do the majority of the setup, but just add info into the zgemma and learn how to set it up to re-tune it, when it gets knocked by the wind, and to other sats.
            • BRUTUS
              • 37
              I think they want to know how to setup zgemma with motorised dish, i did ask this years back and still can't make it move my dish...or it will move it once and that is all... I gave up at the end.
                As long as your dish is aligned right just enter your long and lat tick send disq and thats it basically
                • cunny
                  • 4915
                  As maca said. Quite easy really just get the basics right
                  • P&D
                    • 2686
                    Borrowed from another forum......cannot link it
                    first of all make sure your lnb cable connect to right port see picture below
                    now press blue button on remote and scroll down to tuner set up
                    now press right arrow on remote to tuner configuration
                    select tuner A
                    change the setting to picture below and add your longitude and latitude
                    press green button to save
                    your motor should run fine
