Is it possible to delete the dark none working channels and replace them with working IPTV from my subscription ones and stop the none working ones from coming back each time my bouquets update?
Replace 'dark' channels with IPTV ones
Tags: None
I take it you're talking about ABM? You can replace the non working channels with IPTV channels but when you rescan the bouquet will be replaced and the upto new bouquet will be produced, whether you can add the IPTV channels to the custom 'sd_sat_282_sky_uk_CustomLCN.xml' or 'sat_282_sky_uk_CustomMix.xml' and it will keep the channels is something I haven't tried it, it might work it might not but it could be worth a try, both these files are located at /usr/lib/enigma2/python/Plugins/SystemPlugins/AutoBouquetsMaker/custom . Some instructions on how to modify the files are in the thread download here;
This Backup Image is for the Newer H series of Zgemma Satellite receivers, it will work on the H.S and H.2s and confirmed working on the H.2H by Hadron @post #116 (requires additional setup for cable see post #119) but hasn't been tested on the H5 Openatv5.3 Backup Image with New improved Sky Skin, OTA update safe ?
