Zgemma h2s ..kodi
  • dianered
    • Jul 2010
    • 235
    Zgemma h2s ..kodi
    Hi all can you still get kodi on this box??? Been through extensions but kodisnot there?? Also what is the one to download for 3 oclock kick off thanks all for looking
    you can install a Kodi-Lite plugin but you will not get Full Kodi the machine does not have the horsepower to run it
    • martin035
      • Apr 2014
      • 1308
      And just to add to what digicon has stated once you've installed kodidirect your will then need to install a kodi add-on for the 3 o'clock footy, for free ones you will need to use a VPN as without one most streams will fail, Google will assist you with this.
      A paid for IPTV sub will work better and be more reliable, sportsmania is very popular but I don't know if they are taking new subscription at the mo, but Google is your friend.
      To install the sportsmania add-on follow the instructions in post 2 of this thread
      This Backup Image is for the Newer H series of Zgemma Satellite receivers, it will work on the H.S and H.2s and confirmed working on the H.2H by Hadron @post #116 (requires additional setup for cable see post #119) but hasn't been tested on the H5 Openatv5.3 Backup Image with New improved Sky Skin, OTA update safe ?
