Octo LNB x2
  • PJD
    • Jan 2016
    • 70
    Octo LNB x2
    I need 16 feeds basically,
    Installing Freesat in my new house, Id like twin feeds in each room so If I ever wanted recorder boxes in there I can.
    My question is, Can I Use 2 x Octo LNB's on a single Sky dish? or maybe a different dish if poss, Id prefer the 1 dish to keep it looking as tidy as possible, if I cant then I will have to make do with 2 separate dishes
    you would be better using 1 dish with a Quattro LNB and a Loft Distribution amplifer
    • PJD
      • Jan 2016
      • 70
      I didn't think you could split Sat signal in that way?
      I assumed you needed individual feeds from the dish?
        You can with a Quattro LNB and a suitable Loft Distribution amplifier, the LNB has 4 separate outputs for the Frequency Bands HH,HL - VH,VL the amp then takes these bands and feeds them into 4,8,16,32 etc.. outputs to do what ever you please.
        Have a read: http://www.satcure.co.uk/tech/multiswitches.htm
        • PJD
          • Jan 2016
          • 70
          Been looking into this more and pricing up parts, its gonna be too expensive to run it through a Sat loft distribution amp, so gonna stick with 2 dishes and 2 x Octo LNB's then run each point to each room,
          It would have been nice if I could have gotten away with 1 dish but I cant justify the cost of the setup
          • irorwayrix
            • Jun 2017
            • 14
            Octo LNB x2
            Twin Pin LNB provide Stronger Signal than Single Pin ? I know twin PIN lnb is used for 2 receivers while single pin lnb is for 1 receiver, is it true ?
            • hongkongfooi
              • Aug 2015
              • 19
              Can you use a sly dish and 2x ltb to get Eurostar as form in is z no go in out parts
