ZGEMMA H.2S MAC ADDRESS ISSUE
    Lads bought 2 Zgemma H2S with edentical mac address, is there a way round to change.
    Mac: 00:00E:AD:BE:EF
    Dead Beef
    Thanks in advance.
    28 views not 1 person with a clue....
      I had the Usual Look around 'Google' but not much information on the MAC change apart from an E2 Script which will change it but this needs to be run everytime you switch the box on, So not an ideal solution
      • lincsat
        • 1228
        In a ViX image, look in the Network setup for the "Network MAC settings"
          lincsat thanks found 1 on this one as long as you keep the old software, sorted.
          • cunny
            • 4915
            Yes it can be done. I had to do it on 2 solo2.
            I will see if I can get the info soon as working away.
            Pm m8
            Ps when I'm home I will upload the files to this thread.
            You just ftp them to correct folder and they will change the mac for you.
            If I remember correctly you have to edit a file in correct encoding to the desired mac address. Again will update late weekend.
            Cunny
              Pm m8
              Cunny
              Thanks cunny looking forward for instruction.
              • cunny
                • 4915
                How to change Mac address on enigma 2 stb
                OK before you try the following make sure you make backups as if it goes wrong your network could become unstable and you might have to reflash but this just worked for me.
                FTP to etc/network/if-pre-up.d
                Here you should find a file named cm
                Copy to desktop and open in notepad++
                You will see your mac address.
                Change to desired mac address, save and then FTP back to same location
                Reboot box.
                Done
                Keep this file safe as if you reflash your box it will revert back to original mac and cause issues again. (i just backed up the contents of the network folder and FTP it back after a reflash)
                Let me know how you get on
                  Thanks cunny I will have a go on Sunday.
                  • cunny
                    • 4915
                    Keep me upto date mate and any issues will help sort it
                      Sorry cunny yes all sorted very good techniques I have been very busy this week in the garage I did not get time to open my pc late coming home and was tied I thank you for this peace of advice.
                      • pr3tty
                        Guys
                        Hoping you can help me here. xtremetv been working fine on a Sucmnsee build. Decided to try ipab image and noticed my Zgemma is advertising a different mac address. going back to Sucmnsee image its now still using the "Original" MAC. when i check info on the Xtremetv page i see 3 macs listed (one being the one i gave to my provided). any idea how i force it to take the mac i gave the provider.
                        Have tried contacting my provider but no luck on that front yet.
                        Thanks in advance.
