which HD reciver?
  • gibbo74
    • 445
    which HD reciver?
    HI All
    im looking to upgrade my reciver to an HD one , currently got a tm600 linux which ive just got the hang off but now im looking for a HD linux box be it technomate or dreambox or azbox ,could somebody give there opinion on which is best and eeasyest to use
    cheers
    gibbo74
  • Sat-Shop
    • 275
    If you are used to the TM600 then the most obvious choice for HD would be the DM800, it's still the only (other than it's big brother) to work directly with CCcam as client and server, plus it works very similar to how your TM600 will have done, it's Linux Enigma 2 based so you shouldn't have much trouble getting to grips with it... They do come in at ?389 though.... If you're not looking to spend quite that much take a look at the Coolstream HD-1, I think this could well start turning a few heads soon (it already has some!), it's Linux based and already has a big following with a lot of third party support and can even work (as client only) with CCcam, at ?249 given the spec. its got it's well worth adding to your 'worth a look' list.... We should have more stock of these within the next 2 weeks (I'm hopeful it'll be sooner).
    • dizzy
      • 36
      Thats interesting what you say about the coolstream, would you recommend a particular forum for reading up on this box. How do you rate it against the icecrypt hd which has dual tuners for just a little more money.
      • Sicilian
        • 168
        Just looked up the specs of the ICECRYPT S4000HDPVR, looks good on paper. Have you seen much support for these? Such as CCcam etc?
        D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.
        • dizzy
          • 36
          I know that it runs incubus, and that apparently someone has got it running as an Octagon 1018 which has a lot of support. Satdudez have just started posting a bit about it as well. The reason i'm interested in it is that you can get it for ?242 at the moment if you know someone with access to a uni ip address (farnell uni discounts).
          • Manic01
            • 5117
            Spiderbox hd
