How to view on a second TV?
  • Adam_UK
    • 464
    Hi All
    I will be grateful if someone can help. I have a satellie and a receiver in one room and I can watch all FTA channles fine. I have a TV in another room. Is it possible to watch the Sat channels on the second TV by taking a coax cable from the receiver and use a splitter on the second TV so that the coax cable and the antenna cable for the second TV can use the antenna port? On the back of the receiver should I use RFout or Loop Out? I had ago few weeks ago but once I use the splitter on the second TV the TV can only see the Satellite channels and not the free channels coming from the antenna.
  • billy2
    • 1381
    you could try a video sender ,something like this
    Buy AEI DigiSender X2. at Argos.co.uk - Your Online Shop for .
    try it if you dont like it bring it back
    • Adam_UK
      • 464
      Thanks billy2, but I was looking for a cheap solution. I can get an indentical receiver to the one I have with the same price and attach it to the second TV. Is that possible? Do I need to daisy chain the seocnd recieve to the first one?
      • martin-f
        • 535
        how long is the run from 1 tv to the other m8 and if its not to long is wires a problem
        • billy2
          • 1381
          ok m8 if you can pick up indentical receiver you can try this
          dual lnb, Consumer Electronics, LNBs, Dishes items at low prices on eBay.co.uk
          • martin-f
            • 535
            if the run is not to far away get a gold r/f lead plug the 3 conections in the back of the stb then the other end's in to the tv that will give you good results with a lead for about 15 mtrs / 20mtrs at a push
            • Adam_UK
              • 464
              Hi
              It is about 8 meters, I already have cabled between TV1 and TV2 and I was relaying on being able to watch sat on TV2 using one receiver attched to TV1 but once I use the splitter on TV2 the channels coming from the antenna disappers. Is it TV limitations? my TV is LG 5700?
              • billy2
                • 1381
                ?20 not cheap ??? next it will be free
                • Adam_UK
                  • 464
                  The link you out says ?68.49
                  • billy2
                    • 1381
                    link 2 m8 get a dual lnb
                    • martin-f
                      • 535
                      Originally posted by Adam_UK
                      Hi
                      post 6 will work m8 with newer tv's some of my setup is this way
                      • Adam_UK
                        • 464
                        Sorry martin-f I am not sure what to do. I have a coax cable running between TV1 & 2 and it in plugged in any end on the TV and receiver
                        Where do I put the end of the cable on the recieve and on the TV? Do I need an adaptor on any end on the cable? Bear in mind the antenna port on the second TV is already in use and TV2 didn't like a splitter.
                        • billy2
                          • 1381
                          m8 has your satellite receiver has a coaxial output on it ??? if so run the coaxial cable from out in box 1 to lnb in on box 2
                          • Adam_UK
                            • 464
                            I don't have a receiver on the second TV, I am trying to watch on TV2 but using the receiver attached to TV1.
                            • billy2
                              • 1381
                              what box do you have ???
