Sky plus lnb gone
  • poolfan
    • 70
    Sky plus lnb gone
    Hi the second input on the sky plus lnb is not working?
    Is it difficult to replace an lnb on the box or could a software upgrade solve the problem
  • Manic01
    • 5117
    should be 4 outputs on the lnb. Just undo and change connection.Usually 4 port quad lnb is fitted.
    • poolfan
      • 70
      On the back of the sky box i see two dish inputs when i put the cable into one of the inputs i get a picture then i put the same cable into the other input getting no signal?
      • Manic01
        • 5117
        you need both in, one for when you pause/rec tv.
        • poolfan
          • 70
          Checked on signal test getting
          INput 1 signal strength ok
          Input 1 signal quality ok
          When i put the same cable into the input 2 i get
          Input two signal ok
          INput two quality ok
          Input 2 lock indicator ok
          But im getting no picture when i have the cable just plugged into the input 2?
          Should i be getting a picture when its in input 2?
          • poolfan
            • 70
            Im just selling my sky plus box, i moved so i just wanna make sure its working before i sell it. Im testing it off a dish with a single lnb and just swapping the cable from one input to the other on input 1 i get a picture on input 2 i get no signal is being received yet when i go into signal test the strength and quality seem fine? But im getting a no satellite signal been received?
            • Manic01
              • 5117
              Does the other cable from input 2 work when put in input 1?
              • poolfan
                • 70
                Yeah its the same cable and it works fine in input 1, getting picture
                • Manic01
                  • 5117
                  If the sub is not being paid for sky+ then that account will not be activated.
                  • poolfan
                    • 70
                    Yeah there is no sub on the box or even a card in the box, so is that why there is no satellite being received?
                    Why when i go to the signal test i see that quality and strength are ok?
                    • Manic01
                      • 5117
                      Because the signal is there but the output isnt.
                      • poolfan
                        • 70
                        So its safe to sell it on, hate to be passing on something that is broken?
                        • Manic01
                          • 5117
                          if it worked before then no probs.
                          • poolfan
                            • 70
                            Yeah it has i was just worried with no picture, but if its saying that the signal strength and quality are ok, just couldnt figure it out. Give me a dreambox any day.
                            Thanks for the explanation!
