American Terestial TV
  • clem58
    • Aug 2009
    • 819
    If i wanted to pick up american tv channels would it be expensive and how would i go about it. ie would my sky dish be useless for such a project. I want to know if it would be worth the effort or the expense. Or even if i could would i only pick up east coast signals.
  • Superman
    • 520
    Not possible, simple as.
    Super
    • opsmonkey
      • 5379
      Super
      I'll counter this:
      The inclination angles are very close to the horizon, so it is unlikey that you will be able to receive a signal because the satellite is too low in the sky for you to be able to mount a dish as you will not be within the satellite's footprint area.
      The orbital position of the direct-to-home satellites for North America means that they cannot be received with domestic satellite equipment.
      Reception from these satellite will require a very, very large dish.
      I'd stick my neck out and say if you got a 10m dish you'd receive programs from the DISH Network on EchoStar 3/12 at 61.5?W as well as a few other birds using the Conus beam
      However a 10m dish is not domestic equipment..
      Although Superman is right.. technically you could if you lived next door to this, hook a LNB on and ran some coax cable across..
      • Superman
        • 520
        Ahh, i still think we would be pushing the horizon there unless we mounted it up Snowdon then tried? maybe that could work...I'll try some time in my life 15M Dish up a hugh mountain
        Super
