Blimey, things seemed so easy with my T-Rex, to get NDS support all I had to do with plug it in my satellite capture box and it worked with my blue sly card. Since the white card came out I have not been able to use it on my FireDTV and T-Rex cam. So I buy a Diablo 2, but still no luck. I have tried hard to read all the info for CAMS but it confuses the hell out of me, can anyone please answer these questions ? Be much appreciated
1. Where do I put the Keys.bin and Data.bin files (ie what directory on the CAM) ?
2. Do I need to add all the files within the Keys.bin directory (such as CAIDS.xml, etc) ?
3. I hear people say "make sure emulation is on in the menu", but I can't see this option in the menu.
4. I have installed Transformer 0.0.2, do I also need to install 1.0.1 (it came out earlier but seems to have newer version num)?
5.What exactly are "underworld" keys ? Are they used for the Diablo2 ?
6. Should I have the <<<< in the CAM menu on CAIDS or UK for Sly ? Or is that irrelevant ?
Any other layman info appreciated, I get such a headache reading forums with people talking about what sounds like gobbledegook, and always acting as though everyone should know what they are on about.
My simple want is Sly UK via Diablo 2 using FireDTV and DVBViewer. Currently the Diablo 2 doesn't even know there is a smartcard in the unit, I just get "........." when I select the smartcard slot menu bit. But if I put the old blue card in it shows a code.
Heeeeeeeeeeeeeelp
Thanks.
Heeeeeeeeeeeeeelp
Thanks.
