eutelsat 16 east
  • dank76
    • 745
    eutelsat 16 east
    i have just had a 80cm motorized dish today 16e was working fine about 4pm but at night the signal strength goes down and i get no picture. is it hit and miss with a 80cm on 16e
    any help lads
  • opsmonkey
    • 5379
    you really need a 1m to be getting good reception from 16E..
    • karlpowell
      • 189
      I manage OK here in North West with a 90 cm
      • dank76
        • 745
        so its hit and miss with a 80cm dish then the snr is 61 the agc is 85 and the ber is 42000ish any help lads
        • karlpowell
          • 189
          where are you ? , further north of UK the bigger dish you will need
          • piptaps
            • 399
            90cm is fine all weather for 16e. i tested it in the west midlands and south yorkshire
            • dank76
              • 745
              im in the west mids area with a 80cm the info is above please help im stuck
              • opsmonkey
                • 5379
                If you want the digitalb package you need a 1m.. The transponders they use are weak
                80cms isn't big enough for 16e
                • .: JaCkPoT :.
                  Retired Sat TV Addict
                  • 5607
                  @ Dank
                  You have started on the good side of 15threads in the satellite section since you invested in this setup.
                  This number is far too high, you havent been reading enough before and after the purchase of your setup. Some of the threads you also make should have been added to an existing thread of yours, i,e : "freq 16e" and "eutelsat16 east".
                  Im not having a rant towards you, i just want you to know that if you put your questions in a lower amount of threads then those who want to help will get a little more background info and therefore can help you to a higher degree.
                  ___________________
                  In the good old days, I had
                  DM800s HD
                  Openbox S10
                  TM500
                  DM500s
                  90cm FortecStar dish
                  Maxx 110cm Dish
                  Technomate 2300 Motors
                  • dank76
                    • 745
                    Originally posted by .: JaCkPoT :.
                    @ Dank
                    fair comment jackpot i was panicking a bit i have to get use to sats sorry folks
                    • wooper
                      • 460
                      Heavy cloud cover (snow) can have adverse affect, same with heavy rain. SO with 80cm dish, you will struggle.
                      Anyone reading this thinking of setting up, go for 1m, you can have this without permission.
                      • terriers
                        • 580
                        ideally you should have gone for a slightly bigger dish,,but still to lose signal completely at night,,says to me its a poor install,and u need to get him back..where you are you should only suffer a bit of pixellation in bad weather on the weaker digitalb transponders...also ive tried different lnb,s on this bird and the best for me has been the ice 1.2 db lnb...
                        i,m in north notts and even in severe weather have no problems at all off 16e on a very slightly bigger 90cm dish
