Adding an LNB
  • Adam_UK
    • 464
    Adding an LNB
    My satellite system is fixed dish (1m) with 3 fixed LNBs (Hotbird 13 E, Arabsat 26 E and Astra 28.2 E). I can add a fourth LNB, I want to add an LNB which shows English footy and movies (even if they are encrypted) without moving my dish so which satellite can I choose without moving the dish? I think I should pick a stellite with E direction. I looked at lyngsat and I am thinking of Sly Germany on 19.2 E or Eutelsat 16 E?
    The important thing is that I don't move my dish from current location because at the current settings it is working fine and I can get all channels even when it is raining.
    Any suggestion or advice is apperciated.
  • opsmonkey
    • 5379
    19E. is very good.. most channels dual broadcast in english so movies and tv shows are fine.. you also have quality broadcasters like Canal+ there..
    16E is ok with ITV partners and digitalb to name a few..
    you would have to get a very slim lnb to be able to watch 13 and 16E..
    id personally opt for 19E
    • Adam_UK
      • 464
      Is there a special type of LNBs called slim or you are talking about being slim LNb in orde to fit among other LNBs?
      I just want to know what to buy to get this done.
      • opsmonkey
        • 5379
        because there is only 3 degree separation between the two satellites (13E & 16E) you have to buy two very slim thin alps LNB's then adapt them by shaving off a bit more with a stanley knife and file..
        the pic linked below is from a set up with 3 slim then adapted alps LNB's to receive 13E, 16E and 19E
        it is possible just a pain to setup
        • hooley
          • 470
          i suppose it isnt possible to have 1 w, 13 , 19 and 28 set up like that??
          • Adam_UK
            • 464
            I am not an expert but I don't think it is possible due to dish needs moving to see 1 W, although I prefer 19 E on 1 W as Ops said earlier. Let's see what the experts say.
            • opsmonkey
              • 5379
              you're right it isn't possible
              • bongimdu
                • Mar 2009
                • 52
                i think he can do it without cutting
                13E & 16E will need 3 degree satellite sat dish monoblock
                for
                13E & 19E will need 6 degree satellite sat dish monoblock
                easy to find on ebay
                • opsmonkey
                  • 5379
                  you cant run a monoblock then have other lnbs on the same dish.. read the whole post.. he's already got LNB's on his dish for 13E, 26E & 28E
                  • bongimdu
                    • Mar 2009
                    • 52
                    didnt know that , thanks for explanation
