thor 0.8'W transponders
  • plamen.1973
    • Sep 2009
    • 125
    Hello guys.
    I have 1.2m motorized dish with 0.3db LNB and TM 5200d Super with last patch,but I can't get all transponders for DIGI on Thor 0.8'W.
    What I found all V-por.transponders I can't receive.
    12531v/23340 no signal
    12563v/27500 no signal
    12607v/27500 no signal
    12643v/27500 48%
    12687v/27500 no signal
    12718v/18400 no signal
    I have about 70-80% for all another transponders.
    Any help and advice,please?
  • opsmonkey
    • 5379
    yes mate, if you have a 1.2m and you cant get them it'll be a misaligned dish..
    did you install it yourself..?? if so..:
    is the pole 'dead' straight..?
    have you set the right latitude..?
    is the dish set on the motor correctly..?
    have you entered the correct lat & long on your receiver..??
    have a good read of this then recheck your setup mate.. you should easily be busting all those TP's with a 1.2m
    • satsid
      • Aug 2009
      • 815
      Originally posted by plamen.1973
      Hello guys.
      12643v/27500 48%
      Transponders can be different in signel strenth on the same bird.Alot miss this point,Balkan beam is a weaker beam @ 1 west for example.Help this helps.
      • plamen.1973
        • Sep 2009
        • 125
        is the pole 'dead' straight..? pole is straight.
        have you set the right latitude..?yes.
        is the dish set on the motor correctly..?yes.
        have you entered the correct lat & long on your receiver?Do I need to enter lat & long on it? I ask you,because my motor TM2300 no use USAL protocol.I read that I dont to enter lat & long when I use that kind protocol.
        Sorry maybe I write bulshets,because I dont unterstand this things.Please give me advise?
        • dick b
          • Jun 2009
          • 2462
          if you are on diseqc 1.2 you dont need to input lat/long in your box. but if on USALS you do and I think your TM2300 motor will work perfectly well on usals but may need re-aligning 1st.
          • plamen.1973
            • Sep 2009
            • 125
            thank you dick b.I found the problem faulty LNB(wet).I change and now is fine.
