Which Smartcard Reader is best
  • soviet
    • 61
    #16
    Originally posted by Adam_UK
    On a similar subject, I can have only one card in my DB500 but if I have more cards will I need an external card reader? how to connect it to the box? By using the RS232 on the back of the box?
    Ideally if you want to share more cards one will need to build a pc based server. Its not very hard and can be done cheaply. With the DM500 you cannot use the usb card readers such as Smargo or Omnikey as the drivers available are only for Enigma 2 (Dm 7xxx and 8xx series). Not too sure about the rs232 option though mate, maybe someone else knows about this?
    • piptaps
      • 399
      #17
      question still remains. Is there any advantage of using a card reader than a dm500 buit in slot?
      I have been reading cards with dm500 with no issues at all
      • ITS A SCAM !
        • Oct 2008
        • 1140
        #18
        Is it possible to connect another card reader to a dm500s ??
        • .: JaCkPoT :.
          Retired Sat TV Addict
          • 5607
          #19
          Omnikey 3111 serial cardreader
          ___________________
          In the good old days, I had
          DM800s HD
          Openbox S10
          TM500
          DM500s
          90cm FortecStar dish
          Maxx 110cm Dish
          Technomate 2300 Motors
          • BIGKEN75
            yeah i agree
            • ITS A SCAM !
              • Oct 2008
              • 1140
              #21
              will the STB recognise both of them at the same time ??
              • red devil
                • Oct 2008
                • 690
                #22
                or a DM7020 has 2 card slots and a usb port
                • ITS A SCAM !
                  • Oct 2008
                  • 1140
                  #23
                  well i have 2 STB, both with a slot in each of them....and my server even has a omnikey without any local....3 slots No card !!
                  • .: JaCkPoT :.
                    • 5607
                    #24
                    you telling me you got no xmas cards?
                    Make sure you read on how to configure these little things otherwise they will burn your card.
                    ___________________
                    DM800s HD
                    Openbox S10
                    TM500
                    DM500s
                    Maxx 110cm Dish
                    • Adam_UK
                      • 464
                      #25
                      I have a PC Pentium 4 with 1 GB RAM, any Linux OS will be OK such as Redhat?
                      With the cards are these are physical not virtual cards? I mean there are 4 USB ports on the PC so I can have up to 4 card readers or may be use USB hub? Will Linux OS have all drivers for them?
                      • .: JaCkPoT :.
                        • 5607
                        #26
                        telling you how to set up a server is against the rules. you would need linux server os ie, ubuntu server.
                        ___________________
                        DM800s HD
                        Openbox S10
                        TM500
                        DM500s
                        Maxx 110cm Dish
                        • Adam_UK
                          • 464
                          #27
                          Thanks Jackpot
                          I like to play with the software more than anything else because I work in IT so it is something similar to my day to day work, not intended to do anything with C/S.
                          Cheers
                          • red devil
                            • Oct 2008
                            • 690
                            #28
                            anyone got one of these Infinity USB working, not sure if its compatible thats why i ask
                            • icaicm
                              • 100
                              #29
                              hi
                              i have used both smargo and omnikey 3121 and they are both solid.
                              for newcs server omnikey is awesome and runs very good without any problem.
                              for cccam server smargo is the best as you do not have to configure anything just plug and go. also run very sweet.
                              icaicm
                              • 2tone
                                • 483
                                #30
                                hit and miss so it is know people that have it working on a 7020 tryed to get it working on my 8000 but could not get it to work has some thing to do with the drivers but have had it working on a linxu pc server before for some test's
