the time has come to fit the dish
  • yamar1
    • 970
    #31
    wow reading back on this, some laughs i got there in the end though so stick at it lads and don't give up.
    Faster than Faster
    • mario123
      • 383
      #32
      Originally posted by bugaloo41
      Mario the installation guide will work regardless of where you are in the world but you would change your reference satellite to suit. For Ireland 5w or possibly 8w would probably be better though rather than 1w depending on where you are based.
      If you find out your latitude/longitude from dishpointer the general rule would be to use the nearest sat to your longitude (e.g. -6.0 would be 6w so find the nearest sat to 6w). Use
      LyngSat - Lyngemark Satellite to help you.
      5w you could use NRJ Paris 11096V 29950
      8w you could try Ishtar 11070H 2100
      Just make sure you use a FTA channel when fine tuning.
      Good luck.
      yeah ok mate so im in belfast dishpointer said
      Latitude: 54.5756?
      Longitude: -5.9278?
      so wat would be my ref sat i use? i couldnt find it in the other site
      • dick b
        • Jun 2009
        • 2462
        #33
        your due south sat would be 5West but you can still use 1West if you prefer.put your latitude on the motor bracket 54.6N and the same latitude and 6.0W in the set top box.you can then send the motor to your chosen target sat while its still on the bench.
        • girovend
          • 158
          #34
          Originally posted by yamar1
          cheers, i wasnt sure if the k bracket went to the top as iv seen them either way round. also is it best to mount the motor/dish between the t&k brackets on the pole or above the top bracket? thanks for the help.
          Did you end up installing it above or between the Brackets , and did you
          put the T or K to the top,
          I just watched a video on youtube , and they put the K on top
          • mapex
            • Jul 2010
            • 209
            #35
            Can i ask how high you set it up ? mines is lowish but my
            new 1.1, i'm thinking maybe i should take it higher up my building...
            the old story with heights...they scare me but no pain
            no picture....
            • yamar1
              • 970
              #36
              i put the K at the top and mounted the motor/dish just below the k bracket on a standard 1m scaff pole,,, its never flinched in 6 months.
              Faster than Faster
              • yamar1
                • 970
                #37
                no picture....
                it can be on the ground as long as you have line of sight.
                Faster than Faster
                • mapex
                  • Jul 2010
                  • 209
                  #38
                  What i meant was are you putting yours up on the roof,
                  on the wall...
                  • mario123
                    • 383
                    #39
                    yes finds a transponder but wont scan, starts to scan then just doesent move. thing is i havnt got any channels stored at all on the nablosat image so i cant get a picture as there are no channels stored so i have to scan. maybee il try and upload some channel lists tonight.
                    i was just reading back on this guide coz im gonna install my 1m motorised dish. i not understanding this post i have pli image installed on dm500 i was just wondering if i get it allign correctly with my south sat will it be ready to scan transponders and pick up fta channels for me to test the signal?
                    • dick b
                      • Jun 2009
                      • 2462
                      #40
                      you will need an active transponder for the sat you are setting up on,input this in your motor setup menu to enable you to find your target sat. If using 1W 11.325H 24500 bbc world is a good one. if using 5W 11.591V 20000 france tv is ok.its no good scanning til you have a good quality reading from your target sat but the transponder must be active for you to get a reading.If all else fails connect up a sky box as that will already have the channels in but you will have to send the motor to 28.2E 1st with your other stb set on usals and use this as your target sat.at least you will regognise the programmes to confirm you are on the right sat and once you have tuned the dish in with the sky box you can switch boxes and scan 28.2E and you will have your 1st sat.
                      • mario123
                        • 383
                        #41
                        thx m8. i dont sky box. when u say the transponder must be active the transponer on 5W 11.591V 20000 france tv will be active ok?
                        • yamar1
                          • 970
                          #42
                          download a channel list (motor settings ) direct to the box and then you will have an active channel list and the sat positions/frequencys in the box ready to go. then send it to 1w for bbc world, peak the dish as best you can, evenly tighten the bolts and then your dish should move to the specific sat when you change channel.
                          Faster than Faster
                          • mario123
                            • 383
                            #43
                            hey sorry im lost here : ( i have sat positions/frequencys and some tranponders i seen but no channel list do i need this? can u tell me where i download it if i do? and how to put it on?
                            • mario123
                              • 383
                              #44
                              o rite you mean download direct to the box what buttons or menus do i go into to downloads the channel lists?
                              • 00360362878
                                • Mar 2010
                                • 488
                                #45
                                are you using dm500 or dm800?
