Sky UK Channels
  • Adam_UK
    • 464
    Sky UK Channels
    Hi All
    I use DB500S, one of my LNBs is 28.2E
    I cant see Sky Sports Active channels on my box, are these the same channels you get when you press the red button on your sky receiver?
    I looked in lyngsat and I put the TP manually 11758 H 27500 2/3 and scanned but no channels were found, I am using the latest satellite.xml file
    Can someone help please?
  • dctyper
    • 2539
    i think so, ive seen footie on there before
    • Adam_UK
      • 464
      I can get all sky channels (well almost) but these channels don't even appear on my channels list. Pressing the read button on DB500 won't help here.
      • dctyper
        • 2539
        the red button is a function on sub boxes only. dl settings from the web and you should get them
        dc
        • JediMind
          • 9
          they are set as data stream open your channel list in DBedit or another channel editor then set the channels as tv streams.
          I think they are...
          10935/22000/v/ 5/6 (1391 to 1399) Sky Sports Active
          11758/27500/H 2/3 (1381 to 1389) (1481 to 1489)Football First
          theres also BBC red button
          STREAM-0 / STREAM-6, and T7 STRM-0/1
          • Adam_UK
            • 464
            Thanks guys, I dl the settings. Changed them from Data to TV. But I see all these channels showing the same stream, possibly I need to change the VideoID and AudioID for each channel?
            • soviet
              • 61
              probably download the vhannibal settings for 19.2e, 13e and 28.2 e. Delete the sats you dont need and he has organised all the stuff in good bouquets.
              • Adam_UK
                • 464
                I didn't download any settings, I used DBEdit to get the satellite file and changed the channels on 10936V and 11758V from Data to TV and sent the file back to the box.
                • JediMind
                  • 9
                  they are all the same most times i've looked.
