Not sure if this topic as been covered. Is there a way to assign channel numbers to the programmes in the EPG inwhich have been downloaded Ie. 101 for BBC 1, a bit like the S*k numbers?
EPG Channel Numbers
EPG Channel Numbers
George2000
Currently Using DM800 HD with Nabilosat Black Hole V0.12 with Mbox 0.4 BETA build 0023 and Newcs 1.67
Tags: None -
Any clue as to what receiver you are talking about.
Yes Sorry it is a DM800 HD with a NabiloBlackHole 0.12 Image
George2000George2000
It will be very hard, or should I say time consuming. I cant be bothered anymore and use the premade settings such as Vhannibals settings etc.
You will need to use dreabox edit to download your current channel bouquets onto your pc and edit the channel lists. To have BBC1 as channel 101 you must fill up the channel list below 101 with dummy channels. This takes a lot of time and does not look good on the epg.Comment
Sorted it now found a file from a link ( SKY UK BOUQUETS which does just what i want for nowGeorge2000
