Loose Motor at its nozzle
  • NewBirth2010
    • 56
    I have a Moteck 2100 motor. The problem is that it is loose. I slightly feel the dish moving in the air (left and right) when I hold it with my both hands.
    Any ideas ? Is this behaviour normal?
    Thanks M.
  • dick b
    • Jun 2009
    • 2462
    there should be no play are you sure its just not flexing,what made you check it?
    • NewBirth2010
      • 56
      Thanks dick b
      It is not flexing. I was trying to fine tune the dish. As I said it is slightly loose. It plays a bit, I feel it. This is enough to create problems in fine tuning.
      • Manic01
        • 5117
        No way of tightening then? I have same motor and no slack.
        • NewBirth2010
          • 56
          Are you sure? Not even a slight slack?
          You feel it rock solid?
          Thanks.
          • Manic01
            • 5117
            Within reason, not checked lately as it's on the wall .
            • NewBirth2010
              • 56
              Within reason !
              Would you say that the slack is normal?
              • dick b
                • Jun 2009
                • 2462
                no you should have no play.I have a couple of technomate motors and they are dead firm.these have a bolt going through the neck of the tube and if not tightened right up the tube can rock on the output shaft a lot.
