Faulty dish motor ?
  • mintoe
    • 22
    Faulty dish motor ?
    Hi all,
    I have a motorised dish setup which has'nt been used since december, I've just upated the firmware (Echolink) tried to use it and the motor won't turn ! I then put old firmware back on
    but same problem , so possibly motor died ?its about 6 years old
    H to H mount. is it possible to repair the motor?
    What is the best way to test please ?
    ........mintoe
  • dick b
    • Jun 2009
    • 2462
    Originally posted by mintoe
    Hi all,
    ........mintoe
    is it a 36V H to H or a diseqc motor? most diseqc motors have a manual button on them and an indicator light.if it is a diseqc motor you can replace it for under ?50 now.
    otherwise you can test with a volt meter at the motor.
    • mintoe
      • 22
      Hi dick b ,
      its Diseqc I believe, been using Usals for positioning
      A.T.B..........mintoe
      • mintoe
        • 22
        Hello to all ,
        it appears that firmare upgrade wiped settings.
        All OK for now
        Thanks................mintoe
