satellite dish help
  • dan20leeds
    • 168
    satellite dish help
    Ok so i have a 90cm dish, 1 lnb, pointed at 28.2e but i want to receive italian channelson 13e.....how do i do this? thanks
  • kevin64
    • 170
    add a motor
    or add a twin lnb
    • dan20leeds
      • 168
      how much do they cost?
      • opsmonkey
        • 5379
        google it mate.. they are around ?45 for the motor..
        you wont get a twin lnb with a 15? separation
          No but he might be able to get a multiple LNB holder for the dish, depends what make. Try google for dual lnb holder and the make of your dish if known. That way you can (more or less) just add another LNB offset from the one you're on and keep one LNB pointing at 28e and one at 13e. Quicker than a motor.
          • dick b
            • Jun 2009
            • 2462
            best bet is the motor it will take a bit to set it up but will give you access to a lot more sats including 28.5/2 E and 13 E. your 90cm dish will be fine check out the "how to install a motorised dish" in the sticky section.also have a look at this quick guide I"m sending its for Technomates but others will be similar
            sponsors will sell all you need.
