hi all can anyone recommend a sat system for a newbie, budget of about ?300.. thanks
set up recommend
newbie system
hi m8, and welcome. id say a 1meter dish/quality lnb/usals motor/t+k bracket and pole/ technomate tm 600 stb. with a 1meter motorised system you will get most sats from 45e to 45w( if you have no obstructions) and the receiver can use cards/cams or internal emulators and it also has a lan socket so you can go the c/s route if you want. this is just my opinion and alot of members would say different, other receivers you should have a look at are the protek/nanoxx and the spiderbox. basically you will need a motorised dish and a receiver with a lan socket for the dodgy stuff!
DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W -
Would agree with mdt on all except for the technomate but that is only because I prefer the dreamboxes to most other boxes. You also need to consider if you are going to go up ladders to do the dish installation or are you going to pay someone to do the installation.Comment
