Hello so I have a 90cm dish which is pointing at 28.2e at the moment, I want to be able to pick up another satellite say 13e or whatever for example, what's the cheapest way to do this? thanks
LNB - MOTORISED
you could also get a bracket for your dish that allows you to fit more lnbs to it . your dish is quite big so you could easy fit 2 more lnbs to it say for hotbird 13 east and astra 19 east and you would need a switch to switch between the satellites. you could fit that your self would be a less expensive option. of course you need a reciever capable of multisat as a sky digibox is not really anygood for anything other than sky. as jackpot says a motorised system is a good option (they are cheaper these days) if you can afford it why not.i love it when a dreambox comes together.
here .you see types
Inverto Multiconnect LNB kit. 20 degree, 3 & 4 LNB bracket from the Satellite Superstore UK. 3 satellite bracket.
lots cheaper on ebayComment
