THE New PROTEX 9700HD ip
  • ALAN 1
    • 60
    Tech spec for PROTEX 9700HD ip
    High definition satellite TV receiver for European TV broadcasting
    Fully compliant with European satellite Digital TV (DVB-S/DVB-S2)standard
    HD MPEG-4 AVC/H.264 HP@L4, MPEG-2 MP@HL
    &SD video Decording
    Selectable HD Video output Resolution Format 1080i/720/576 @50HZ
    RF input Range 950MHZ~ 2150MHz with a High sensitive Tuner
    QPSK & 8PSK Broadcasting Signal Demodulation
    High speed 32bit risc microprcesser up to 266MHz
    HDMI High resolution Analog HD video output to RCA connector
    Scart connector for non HD TV set
    Dolby Digital (AC-3) 5.1- channel & MPEG Audio Decording
    MAX (9.999TV) + (4.999 Radio) channel Memory capacity
    Fast channel searching &Fastchannel change switching speed
    Channel list & Favorite channel list edit programming
    Quick find function for finding desired channel with just alphabet as channel name
    HDMI/YPbPr Digital/Analog simultaneous HD video output
    High resolution Full colour on screen graphic display
    Optical S/PDIF Digital audiooutput for AV receiver Amp RCA cinch analog video (composite) & Stereo
    Audio output for TV or VCR
    Electronic program Guide (EPG) for on screen channel information
    European Teletext & DVB subtitle Display support
    DiSEqC 1.0 1.2 & USALS support for controlling LNB and motorized dish
    1-slots Smartcardinterface for usage with Pay- TV- channels
    High speed software update Through USB 2.0 Host interface
    (USB PVR Function Ready to External HDD (HARD DISK DRIVE) up to 4TByte)
    RJ45 ETHERNET PORT
    MULTI- CAS support.
    (CONNECTS JUST LIKE THE PROTEX 9600ip to server)
