no satellite signal is being received 29
  • monu
    • Feb 2010
    • 7
    i recently install sky dish in my new house but i getting error no satellite signal is being recived code 29 i did signal test network id 0000 transport stream 0000 signal quality nothing lock indicator not locked
  • Manic01
    • 5117
    Error message 29 usually indicates that the box is not 'seeing' the default transponder. Have a look at ( Services>4>01 Select ) the Default Transponder settings, and make sure the values are 11.778, V, 27.5. 2/3. Reset ( red button ) and Save New Settings.
    • Manic01
      • 5117
      Or try this.
      To reset the LNB:
      1. Press services on your Sky remote control.
      2. Highlight System Setup using the up/down arrows and press select.
      3. Press 0, then 1, then select.
      4. Press select again to access the LNB setup screen.
      5. Using the up/down arrows, highlight LNB Power Supply.
      6. Using the left/right arrows change the setting to off.
      7. Using the up/down arrows, highlight 22KHz command.
      8. Using left/right arrows change to off.
      9. Using the up/down arrows, highlight Save New Settings and press select.
      10. Press sky followed by services.
      11. Highlight System Setup and press select.
      12. Press 0 then 1 then select.
      13. Press select again to access the LNB setup screen.
      14. Press the red button to re-set the default settings.
      15. Using the up/down arrows, highlight Save New Settings and press select.
      16. Press select to confirm that the settings have been reset.
      The correct settings are:
      - 9.75 for the low frequency.
      - 10.60 for the high frequency.
      - The LNB power supply should always be set to on.
      - The 22KHz Command should always be set to on.
      17. Press sky to return to normal viewing. It may take 60 seconds for the picture to appear. If this issue is affecting the playback of recorded material, you will need to make a new recording to check whether this procedure has resolved the issue.
