fausto 1.43
  • 2tone
    • 483
    fausto 1.43
    Dont think this has been posted here yet dont know why but with fausto 1.43 it opens Canal Digitaal (19.2?E, Irdeto 2, ID 0000) and TV Globo Internacional Keys (13?E, Nagra 2, ID C102) also has Viasat hack in it
    Fausto
    (C)MASARE Team-Saoud007
    (C)FullDump TM
    Special thanks to s62,Snakie,Bordan,Rekordc & KarraKarra
    FAUSTO KEYS EDITOR/EMULATOR/LOGGER/CLIENT/SERVER
    Installation: not needed to uninstall previous version, just run Fausto V1.XX setup.exe
    Fausto Emulator compatibilities:
    *XML file to be compatible with Fausto Emulator MUST include cryptoworks Cardkey (06)
    This keys used in internal by diablo cam emu
    If the CardKey (06) not include you'll can't decode cryptoworks with Fausto Emulator
    CardKey (06) added on Keys.bin has no effect under diablo cam emulator
    *Include Betacrypt Tuneled Nagra 2 Providers
    *Include ECM IV & ECM Seed keys under Irdeto2 Coding System
    CS Cards Client supported:
    CCCam (TCP)
    Newcamd (TCP)
    RadeGast (TCP)
    Camd35 (UDP cs357x)
    Camd35 (TCP cs378x)
    Camd33 (TCP)
    Gbox client (localhost only, default ports)
    Twin Protocol (Serial)
    CS Cards server supported:
    Newcamd (TCP) & EMM Support
    RadeGast (TCP)
    Camd35 (UDP cs357x)
    Camd35 (TCP cs378x)
    Camd33 (TCP)
    Support:
    - Ethernet (linux box, diablo wifi,...)
    - SSSP/HSIC/TM Share/CSC (Serial)
    - Season Interface (Cams/box Readers)
    - Diablo Wireless (base unit)
    Main Functions:
    - Emulator
    - Logger
    - Net client
    - Card server
    - Cards support
    - DVB Plugins (without pctv card)
    Version 1.43 (15/03/2010)
    - Editor
    Modele.xml modified
    - Emulator
    *Settings files:
    FeSettings.ini modified com parameters about season removed
    Season.ini added com paremeters for each emulation (Irdeto,Seca,Viaccess,Cryptoworks,Conax)
    To keep compatibilities with previous version FE use default settings
    Report To Fausto & Season INI File.txt for more details
    To create default settings file delete existing one, open emulator window and the new one will be created
    *Serial:
    - Added CSC ECM protocol support, 6 versions (Now avalaible SSSP/HSIC/TM Share/CSC ECM)
    Tested with version:
    * Titanium /technocam
    * Tiger t6
    * Starsat
    * Dreamsky
    * GlobalStar
    * Technosat
    Added settings file for named CSC_Cas_Datas.cfg (folder ..\Fausto\Serial\)
    Settings file can be edited via tab SETUP
    Choose CSC_Cas_Datas.cfg on file list
    Press OPEN
    Made changes
    Press SAVE
    Usefull only if ECM not comes from box, it others case NOT required
    *Server:
    Newcamd: Irdeto EMM code improved
    Log File: can be produced without ECM Debug ON
    *Client:
    -Added possibility to set Connection Max delay
    Report to file FaustoClients Example.cfg dor syntax & example (Folder Fausto\Emu\CardClient)
    -Added Twin protocol
    For client definition report to FaustoClients Example.cfg on folder \Fausto\Emu\CardClient
    For more informations read file Fausto & Card Client.txt
    Joined file twin_cache.cfg (Folder Fausto\Emu\CardClient) with somes channels example, add your own
    -CCcam:
    Accruate compatibilities with Nagra3 provider (specially with card read by Newcs)
    Added default provider zeroed when only caid defined for a card
    -Log File: can be produced without ECM Debug ON
    *Cards:
    TNTSat Default AES key added if not set on Cards.ini file
    Sky Ita card fix
    *Setup:
    Added posibilities to edit file
    CSC_Cas_Datas.cfg
    twin_cache.cfg
    Include syntax definition
    *Language file:
    Added [Strings] datas
    Added Russian language file thanks to the author
    Special Thanks to:
    JKF Intersat Forum for all support give to our tools.
    All guys for language files & translation:
    MagicTrance, superseeder, sYgNaL, mcolaciuri, Seti72, Alaancee, Jogo1967, GarField57, Claudio_LDN, S62, Professor Moriarty, Twister, Stauffie, Anunaki.
    Enjoy.
    fausto 1.43
    h**p://www.megaupload.com/?d=WMOFZVL8
    Also load this key file from link below
    h**p://www.megaupload.com/?d=5FIP30C9
    Bonus: Canal Digitaal Irdeto2 worked
    Worked ONLY under Fausto
    C+ NED (Ird2) Fausto server & internal emu
    1.Open Emulator window
    2.Under Monitor Load Keys.bin
    3.Side client create a connection to fausto server
    4.Under FaustoServers.cfg create server line access & save changes
    5.Clic on Tab Manager
    6.Press Load
    7.Press Start
    Channel will be decoded
    Example with Newcamd line:
    1.Client N Line (CCcam.cfg) -> N: 192.168.5.11 18000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    2.FaustoServers N Line -> N: 192.168.5.11 18000 0102030405060708091011121314 {0622/000000}
    U: dummy dummy
    Latest Canal Digitaal NL Keys (19.2?E, Irdeto 2, ID 0000)
    Worked ONLY under Fausto v1.43
    16/03 Active key 02
    0622:000000:02:02:[E32EB7E21DDBBB3BD76C19533B1E30C6]; C+ Nederland (19?E)
    17/03 Active key 03
    0622:000000:03:02:[A65E34C26F112F250CB0CCF7B0FA8A69]; C+ Nederland (19?E)
    How to update keys file
    Run Fausto
    On Main Menu clic on File
    Clic on Load Keys File (select & open file Fausto_Multicam_Keys.XML)
    Double Clic on Coding System Irdeto 2 to expand keys list
    Select Key wanted (on screenshot joined key 02)
    Enter or copy/paste new value for key
    Clic on File menu
    Clic on Save keys File
    Changes can be done when emulator running, in this case under Tab Monitor, just reload fresh keys.bin
    Hope it helps
    MASARE Team
  • DEMONACER
    • Jun 2009
    • 122
    For Technomate models goto menu - options - and turn on SSSP then save and reset box and you will have no problems using Fausto.I used it for a while and it a good piece of software.Plenty of keys available too.
    • 2tone
      • 483
      The funny thing is i dont think people see how good fausto is full support from a good dev team can read most cards that are out there and any hacks that are going about can be used
      • bugaloo41
        • 1598
        tone thanks for the post mate.
        Excuse my ignorance but is this used as a softcam or is it used on a diablo cam? tried to do a bit digging with this but not having much success but probably me not understanding things correctly. Certainly like to give it a try on either dm500 or tm500.
        Any assistance gratefully received.
        • plamen.1973
          • Sep 2009
          • 125
          Do I have to use any cards?
          I use only Softcam.
          • DEMONACER
            • Jun 2009
            • 122
            These guys are doing files for Diablo2 and if all goes ok they just might save the D2.
            • 2tone
              • 483
              fausto is an emu that runs on your pc you would be able to link your tm500 and dm500 to it and get it to share any off the hacks it supports to these receivers as long as you have the right key files loaded in to fausto you can also use a card with fausto and share it to your receivers if you have an old cam as well for talk sake good chance fausto supports it so you could link a season Interface to your pc and receiver and it would work but as you have dm then you just need to set it all up on a net work
              • 2tone
                • 483
                I use only Softcam.
                fausto will let you load keys for some of the open providers out there at the min and share to a couple of receivers in your house like a dreambox or so on
                • bugaloo41
                  • 1598
                  Thanks 2tone will give it a try tomorrow.
                  Played about with the software seems simple enough to use just not sure what best softcam to try. Nothing ventured nothing gained.
                  • 2tone
                    • 483
                    21/03 Active key 02
                    0622:000000:02:02:[7836D30B93FB0A655EB203F2295390F2]; C+ Nederland (19?E)
                    thanks to masare team for this
                    • 2tone
                      • 483
                      fausto now opens nova on all emus thanks to masare team
                      6.Press Load
                      7.Press Start
                      2.FaustoServers N Line -> N: 192.168.5.11 18000 0102030405060708091011121314 {0604/000001}
                      U: dummy dummy
                      • bugaloo41
                        • 1598
                        Thanks 2tone. Gonna give this another whirl. I could not crack this 1st time round using various softcams on a TM500. Probably somethig silly I am missing though. I couldnt locate anywhere in Fausto how to set it up to your network (ip address) any pointers gratefully received.
                        • mdt
                          • 3034
                          ive seen on another forum that n*** cy is open using this type of emu!
                          • kb27
                            • 14
                            Hmm. I can't seem to get this up and running with my DM500 either.
                            Always getting login failed. Any clues?
                            • dragoshel
                              • Apr 2010
                              6.Press Load
                              7.Press Start
                              U: dummy dummy
                              I'll give it a try
