sky box engineer tricks
  • sorsat
    • Dec 2011
    • 8
    #151
    Power supply start up caps have dried out , you may be able to get it repaired or just bin it and pick one up off flea bay? Cheap as chips
    • harrynog
      • Jan 2012
      sky box reset
      Hi all, just registered , i have lost my signal on sky+ box ,sky seem to do this every couple of years because i wont upgrade to hd (another ten quid a month) i did purchase a disc last time and accsssed secret codes and fixed problem. cant find disc and am anxious to watch my footie tonight can anybody help, box is an amstrad thanks
      • digital maniac
        • Jan 2012
        system reset
        thanks for your help. it got my thompson unit back up and running again after a complete failure and no signal!
        could not find system reset so did the stage 3 which worked a treat.
        now i am going to buy a better box!!
        • storm95
          • Jan 2012
          #154
          sky reset
          trying to reset an old sky box pre sky plus
          any help
          • EAMO 2
            • 1201
            #155
            any help
            Read tutorial on page 1 of this thread, follow procedure & post
            back here with DETAIL if procedure is not successful. Plenty of help on here but you are expected to make some little effort first
            • Feral Space Monkey
              • Jan 2012
              Thanx for all the tips. I took my box apart to try and retrieve the recordings using the COPY + software, but unfortunately it the particularly complicated 500gb Amstrad box has had a software update to the dreaded DARWIN version and Copy + doesn't currently support this Anyway, I've had to forego all the months of recordings and bite the bullet, with a full system reset. Never mind, at least I can record and pause TV once more. Thanks again, F.S.M.
              • 3y3k0n
                • Jan 2012
                Thank you for The post.
                Thankyou very much for the useful and informative post. Do you know by any chance what the concealed cam interface is for at the back of the sky boxes?
                • EAMO 2
                  • 1201
                  #158
                  Never looked at it, don't use S*y boxes really, but would hazard
                  a guess if you try accessing "concealed cam interface" response
                  would be ACCESS DENIED
                  • lawler83
                    • Jan 2012
                    can you help? recently bought a secondhand sky+ HD bod (ex west mids area) we live in Yorks... our sky card (with subscription) wont work in the new box.. is there any way round this?
                    • Manic01
                      • 5117
                      #160
                      Phone sky to get it paired to receiver. It's free to do.
                      • DEK2000
                        • Feb 2012
                        Originally posted by joe516
                        sky/sky+ box, use these tips to enter secret menu to reset/defrag
                        Any tips would be gratefully received thank you.
                        • oldgit71
                          • Feb 2012
                          #162
                          I have just cancelled Sky and they have removed my ability to record and replay recorded programs on my Sky+ box. Is there a way to override their programming or has this been done on the viewing card?
                          • Manic01
                            • 5117
                            #163
                            ?10 per month req to use rec function.
                            • oldgit71
                              • Feb 2012
                              #164
                              Thanks, trying to avoid using sky at any cost so trying to get round the problem in different ways as I now have a useless Sky+ box
                              • Manic01
                                • 5117
                                #165
                                If you have an older version sky card, blue house if it had sky+ activated on it.
                                It will still let you use rec facility.
