be4 i start thankz 2 every-1 who helped me get it setup..i have installed moterised system package, im using a technomate tm-5400 ci+ the max im getting is around 65/75% signal is this ok..the arc is perfect i can hit nearly all satellites..my m8 told me that the lnb they sent me is about 4.99 to buy if i buy a good lnb do you think it would inprove..and could any-body tell me a good 1 for a 1metre dish.last question im using a diablo cam do the keys work conax aswell thankz paul............
installed new satellite system..little help needed
hi m8, a different lnb might get you a bit more signal but as long as you have a stable picture and a decent weather margin your lnb is fine, a bigger dish is always better for more signal. as for a good 1m dish id say a triax or gibertini but ive used orbital with very good results on badr4 with a smart lnb. if you are getting the channels you are after with a 80cm dish then why change?, although bigger is always better for the weaker transponders if you must have everything. if money isnt a problem then have a look at the andrews 1.2 meter but you would also need a heavy duty motor and v-box, alot of it is down to personal preference and your perticular set up and location. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
