12345678 or 12 34 56 78 ??
  • ITS A SCAM !
    • Oct 2008
    • 1140
    When using Debian Server
    can anyone finally please advise me
    Is the Boxkey either entered like this
    BOXKEY : /dev/ttyUSB0 xxxxxxx
    or
    BOXKEY : /dev/ttyUSB0 xx xx xx xx
    Thank you
  • weeman2010
    • Mar 2010
    or
    BOXKEY: /dev/ttyUSB0 xx xx xx xx
    Thank you
    (i removed the space between
    BOXKEY: )
    • ITS A SCAM !
      • Oct 2008
      • 1140
      so is it xxxxxxxx or xx xx xx xx ??? I do not understand you...
      • .: JaCkPoT :.
        Retired Sat TV Addict
        • 5607
        It is
        Not saying for 100% But most sure it is as i dont have debian!
        ___________________
        In the good old days, I had
        DM800s HD
        Openbox S10
        TM500
        DM500s
        90cm FortecStar dish
        Maxx 110cm Dish
        Technomate 2300 Motors
        • red devil
          • Oct 2008
          • 690
          or
          Thank you
          as weeman said m8 its this
          your original was like this
          so he removed a "space" after BOXKEY to make it correct
          • ITS A SCAM !
            • Oct 2008
            • 1140
            I get it now.......can anyone please confirm that these are correct for a smargo USB reader
            SERIAL READER: /dev/ttyUSB0 smartreader+
            SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB0 3430000
            BOXKEY: /dev/sci0 xx xx xx xx
            I cannot unterstand why there is ttyUSB0 & sci0. Is this correct ? Would they not be the same ??
            • .: JaCkPoT :.
              • 5607
              Sci0 is internal reader i believe
              ___________________
              DM800s HD
              Openbox S10
              TM500
              DM500s
              Maxx 110cm Dish
              • osborne82
                Dreambox Guru
                • 133
                ull need to state box key for both sci0 and usb0
                cheers
                osborne82
                • ITS A SCAM !
                  • Oct 2008
                  • 1140
                  so i need to put BOXKEY: /dev/sci0 xx xx xx xx & BOXKEY: /dev/ttyUSB0 xx xx xx xx in the cfg ?? Instead of just one of them ??
                  • Sat-Shop
                    • 275
                    Only for the card slot you are using the card in that the boxkey belongs to, so if you are using the internal receiver card slot then:
                    or if you are using the Smargo on an USB port then:
                    It's one or the other, you don't need it for both. If you've got a receiver with 2 internal card slots then it's slightly different again, it would be:
                    or
                    BOXKEY: /dev/sci1 xx xx xx xx
                    depending on if it's the first or second card slot.
