fitting sky box to existing sky dish
  • standarren
    • 857
    my brother has just moved into his first place
    Theres a sky dish out side with an old cable running off it.
    i had a sky box that i no works so have decided to rig it up so he has a few channels at least
    but we could not get any signal we tried a new run of cable still no good there was a neighbours sky dish right alongside it well about 10 ft 'could it be the lnb is faulty how likly
    just thinking witch is best to do buy a new lnb or buy a signal finder any suggestions thanks for your time
  • dosyoldcoot
    • 48
    Leave the box plugged in to see if it catches an update signal from sky before you do anything more.
    DoC
    • theGh0st
      • Mar 2009
      • 61
      If the dish is Aligned correctly and the LNB is Ok you will receive a signal on the box, check in the services menu, it could be the coax cable or even the outer strands touching the main copper cable, so you could try removing the F Connector and redoing the connection.
      You could also try a Sat Meter.
      If you have a Sly sub then you will have to tell them you have moved.
      I'm willing to test it for you for free, but it all depends on where in the UK you are.
      System:
      DM7000s | 120gb HDD | Gemini 4.7 | 1m - Multi |
      SpiderBox 9000 HD | SKY+ HD
      System Cable:
      None
      System Broadband:
      Virgin Media 50mb
      | Help is at hand. |
