query on diseq motor
  • halau
    • 278
    what is the difference between say a darkmotor where the pole sits down and a stab where the pole is sitting upwards and any benenfits ?
  • mdt
    • 3034
    haveing installed both types i find the stab version easier to install when up a ladder as it can take the weight of the dish but once they are installed i cant see any difference in performance although i personally prefere the stab although i havent ever owned or installed a darkmotor. regards mdt
    • dosyoldcoot
      • 48
      I agree with the comments from "mdt? in reference to the stab motorand ease of fixing a dish when up a ladder.
      The darkbox might be a little faster and has a slightly larger scan range than the stab.
      DoC
      from the darkmotor handbook
      max size of dish 1.2m
      Azimuth angle, 80east to 80west
      Speed, 1.9deg/sec @ 13v, 2.5deg/sec @18V
      from the stab handbook
      HH100 max dish size 100cm
      Azimuth angle +/- 70deg
      speed, 1.2deg/sec@13v & 1.8deg/sec@18V
      Doc
      • halau
        • 278
        ok thanks
        no difference in settings on motor then
        • dick b
          • Jun 2009
          • 2462
          Originally posted by halau
          ok thanks
          no mate just put your location latitude on it.
          I have always used technomate motors(the open end is down) and put the dish bracket without the dish itself on the stub 50mm from the bottom,I do do this on a bench as it much easier to get it exactly central.then I put a car exhaust clamp on the actual mounting pole before puting the motor/dish bracket up and resting on the exhaust clamp as this makes it easier to swing it L/R when tuning it in.I then mount the lnb holder and dish itself last.but pick a method you feel comfortable with.
          I hate heights so try and mount mine with max height from a step ladder.
          • halau
            • 278
            join the club hate hights but always seem to get lumbered with helping a mate with theres
            was thinking along this line if ended up with a down pole nice tip though
            • arbanasi
              • 7
              quote: //what is the difference between say a darkmotor where the pole sits down and a stab where the pole is sitting upwards and any benenfits ?//
              There is Not Difference,from a Physical and Technical prospect. Its all about Patents and designe.
