Need Some Tech Help NSS7 @ 22.0W Africa
  • jokoda
    • 6
    Ok a friend of mine wanted to take some fta receivers from Canada to Africa to pick up the above satellite over there, l,ve noticed the power supply is compatible over there but the satellite he is talking of is not in the factory default list, l do some search and l found all the Frequencies on tp,s but have no idea how l can create and load the whole thing into this receiver in other for him to pick up this satellite from there.
    Thanks guys for your input and l appreciate.
  • mdt
    • 3034
    it should be possible as most receivers have the facility to add a new satellite and then new transponders. as long as he has the correct details. eg c/ku band lnb, freq, pol, symbol rate. fec then he shouldnt have any problems. regards mdt
    • jokoda
      • 6
      Thanks alot for your reply, yes is ku band so now my question is do l have to enter the tp, symbol rate etc manually, or is there a way l can make a file and then load it. sorry actually this is the link of the sat http://www.tracksat.com/satellite183.html
      Again thanks
      • mdt
        • 3034
        if the receivers have a usb socket and / or are well supported then you could upload a channel list via usb/null-modem lead and channel edit software programme. regards mdt
        • jokoda
          • 6
          Tanks mdt, l really appreciate your help sir... cheers
