Diablo2
  • bosvelt
    • 262
    Diablo2
    Got the diablo cam 2 the other day programed it stuck it in and it opened what it should have, but after about 10 mins the picture started to break up, when i removed it the picture was fine (tohr 1w & Hotbird 13e), Any ideas?
    Sky+ HD Spiderbox 9000hd TM 5400 ci+ 90cm dish motorised
  • benny/9
    • 1964
    the diablo cams work well in all tm models
    so i cant see it clashing with your tm 5400
    unless you have anouther cam in the box at the same time
    because the diablo and dragon t-rex cams are very dominant
    and clash when there's more than one cam in the box
    other than this i would format the cam and load the file again
    also you will need to re-set the configuration to see if this clears
    the probem
    Please Read Carefully!
    • bosvelt
      • 262
      thanks for the helpful info Benny, tried to format cam through cas 8.7, keep getting error message? after about 6 tries it finally formatted, re-programmed it, not to sure what the correct config is a few different conflicts on forum?
      • patkins
        • 3662
        For what it`s worth Bosvelt, I put the latest patch into my TM 1500ci+ and after watching for a few minutes I had a similar problem to yours . I withdrew my dragon loader cam and all stuff reappeared again. Dragon loader was previously formatted for Premiere @ 19E .Maybe their was a conflict? I dont know.
        • bosvelt
          • 262
          Yuo could be right i read on another forum about caids files causing conflicts, so i'll have to remove caids 1 at a time to see if there is conflicts
