hi all im after a solution to a problem i want to set up another dish that picks up 13e 19e and 28e is this possible on a fixed dish using a multi lnb arm and three seperate lnbs or is 13e and 28e to far apart to do this on a fixed dish ? and if can what size dish would be best ?
13e 19e and 28e on a fixed dish ?
Why not get a motor with a 80cm dish and pull in 1w, 5e 10e and 16e as well. costs not much more than multi LNB 1 metre dish and its a lot more compact. To keep ahead of the game go also for cs and a linux box !Comment
You can get 13e, 19e, 28e on a 80cm dish, no need for a 1m dish....
Ues a MONOBLOCK for 19e & 13e and a single lnb for 28e, focus the dish on the 28e location and off center the mononblock, i use this configuration and it works a treat.Last edited by alunfennell; 3 May, 2010, 22:25.Comment
yes u can i'm using 4 octo lnb's on 13E 19E 23E 28E on a 90cm triax dish i use to have a smaller dish and was loosing signal on 19E but now never a problemhi all im after a solution to a problem i want to set up another dish that picks up 13e 19e and 28e is this possible on a fixed dish using a multi lnb arm and three seperate lnbs or is 13e and 28e to far apart to do this on a fixed dish ? and if can what size dish would be best ?Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.Comment
___________________
In the good old days, I hadDM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Maxx 110cm Dish
Technomate 2300 Motors
sigpicComment
