Probably a real dopey Q..
  • OldBloke
    • Sep 2009
    • 162
    As some of you good lads know,the dope is probably me,but Im still learning
    Anyway..when I do a blind scan of a sat is there any reason why Im only picking up Vertical tps ? or is this normal or have I done something when I was trying to get technical?
    Thanks if anyone can help.
    Spiderbox ,1m motorised dish...
  • terry l
    • 92
    Unless you've done something in your setting it could be your lnb packing up m8..
    • OldBloke
      • Sep 2009
      • 162
      more likely Ive done something
      thanks tel
      • mdt
        • 3034
        when your doing a blind scan make sure the pol setting is set to all/both, regards mdt
        • OldBloke
          • Sep 2009
          • 162
          yeah thanks mdt,cheers pal but I have that,I understand you can refine the scan,searching both........
          another thing thats started happening too is that when I manually enter tps Ive found looking round the net,it says invalid frequency when I put them in...yet I see on more than 1 forum identical tps....doing me head,everything was fine a fortnight ago
          • terry l
            • 92
            Is it worth downloading the firmware from the techy site and starting again?..[just a thought]..
            • dick b
              • Jun 2009
              • 2462
              hello mate,
              you havent topped your box memory out have you,you may have to delete some unused TPs/channels before you can put any thing else in.(I"d delete all the dead TPs anyway)
              • OldBloke
                • Sep 2009
                • 162
                Firmware is upto date,dont think its that,cheers Tel
                Hi Dick,alright mate...how do I do that ?..do I do it manually or is there a quicker way mate ?
                • dick b
                  • Jun 2009
                  • 2462
                  I do it manually but you can go into the factory re-set menu and delete all radio channels and you can go into the edit channels menu then delete sub menu then using the red/green/yellow/blue buttons and follow the prompts as to what you want to delete.
                  to get rid of dead Transponders go to the installation menu>PID search highlight transponders ."ok" then scroll through them and delete any that are not active(red).by pressing the yellow button.
