World premiere: Dream presents new HDTV boxes
DM800HD se and DM7020HD at the Anga Cable show
World premiere at the Anga Cable show! Dream Multimedia, the leading supplier of Linux-based set-top boxes, will be presenting two new HDTV Dreamboxes at the trade show in Cologne from 4. to 6. May 2010.
The prototypes of the DM800HD se and the DM7020HD models will be presented for the first time. And there are more new developments from Dream.
The Dream Multimedia HDD Case is an elegant eSata-USB solution for connecting external hard drives to a Dreambox or a personal computer. The case will fit a 3.5“ hard drive, and features the typical Dream design. A particular highlight is that the contents of the hard drive can be encrypted using either a numeric code or a smartcard.
The presentation at booth H40 will, however, focus on the new HDTV Dreamboxes. The DM800HD se features a new DVB-S2 tuner as well as a more powerful processor. In addition to two Smartcard readers it also comes equipped with an HDMI interface. An absolutely new feature in this second edition of the DM800HD is the multi-colour OLED display.
The prototype of the 7020HD, too, features an HDMI interface as well as an OLED display. This Dreambox comes equipped with a DVB-S2 tuner, and also has a socket for an additional plug-and-play tuner.
Appropriately, Dream will be presenting, for the first time, a plug-in DVB-S2 tuner module that can also be used in conjunction with the DM8000HD PVR.
Naturally Dream will also be showing other products at the Anga Cable show, such as the current best-selling Dreambox, the DM500HD and the flagship, the DM8000HD PVR. The Dreambox team looks forward to seeing you at our show booth, H40.
Dreambox DM 800-SE HD PVR
Powerful receiver for digital TV and Radio programs.
Main features are a 400 MHz processor
the Dreambox DM800 SE+ (plus) supports the Linux TV API
have a look to HighDefinition TV on your Dreambox
10/100MBit compatible Ethernet Interface
DVI connector
plug & play Tuner
brilliant OLED display
SATA for use either as internal HDD 2,5" or eSATA
- 400 MHz MIPS Processor
- Linux Operating System
- OLED - Display
- MPEG-2 / H.264 Hardware decoding
- Tuner: DVB-S, optional: DVB-C, DVB-T
- Tuner Module, Plug&Play
- 1 x Smartcard-Reader
- V.24/RS232 Interface
- 10/100Mbit Ethernet Interface
- 1 x Scart (RGB, FBAS or S-Video)
- DVI
- 2 x USB 2.0
- analog modem
- S/PDIF Interface for digital bit stream out (AC-3)
- 64 MByte Flash, 256 MByte RAM
- SATA
- for use either as internal SATA HDD 2,5?
- or to use for extern eSATA
- unlimited channel lists for TV/Radio
- channel-change time < 1 second
- automatic service scan
- directly bouquet-lists
- EPG (electronic program guide)
- multiple LNB-Switching control (supports DiSEqC)
- OSD in many languages and skin-support
- Videotext Decoder
- extern 12V power supply
DreamBox DM800 SE technical data
DBS-Tuner mit DVB-S2:
Frequency Range 950 .... 2150 MHz
Demodulation DVB-S (QPSK); DVB-S2 (8PSK,QPSK)
Symbol rate DVB-S: 2 ... 45 Mbaud/s, SCPC/ MCPC
DVB-S2: 10 ? 31 Mbaud/s (8PSK) , 10 ?30 Mbaud/s (QPSK)
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible, H.246
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Audio decoder:
Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3
Audio Mode Dual (main/sub), Stereo
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical, Toslink
Ausgang Video:
Ausgangspegel FBAS 1 Vss +/- 0.3 dB an 75 Ohm
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS, RGB, S-Video
Serielle Interface RS 232:
Typ RS232 bidirectional
Bitrate 115,2 kBit/s max.
Plug Connector SUB-D-9
Function: Update of Firmware
Ethernet:
10/100 MBit compatible interface
Analoge modem:
analoge modem for Internet connection
SATA Interface:
- for use either as internal HDD 2,5? or eSATAor internal 2,5" HDD
USB
2 x USB 2.0 Host
LNB power and polarisation per tuner:
LNB Current 500mA max.; short-circuit-protected
LNB Voltage vertical < 14V no load, > 11,5V at 400mA
LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
Count of active satellite position:
DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION
DiSEqC - Rotor Control
Power consumption:< 15W at 12V
External PSU
Input:
110-240V AC / 50-60Hz / 0,6A
Output:
12V = / 3,0APhysical specification:Ambient Temperature +15?C...+35?C
Humidity < 80%
Size (W x D x H):195 mm x 140 mm x 40 mm
DVI connector
plug & play Tuner
- OLED - Display
- DVI
- 2 x USB 2.0
- analog modem
- SATA
- Videotext Decoder
Video decoder:
Audio decoder:
Output analog:
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Ausgang Video:
Video parameter:
TV-Scart:
Ethernet:
Analoge modem:
SATA Interface:
USB
2 x USB 2.0 Host
External PSU
Input:
Output:
Humidity < 80%
