will double LNB make any difference, cos thinking of replacing my single LNB with double or Twin LNB to watch free to air channels from Europe
Double LNB
not quite sure what you are trying to do but a twin lnb will simply give you an exta feed for another box.monoblock lnbs have two lnbs in the same case with a fixed angle to recieve two different sats on the same dish usually this is 6 degrees to recieve 19E & 13E at the same time although you can get other seperation angles.if you let us know what sats you want someone will be able to give you better advice. -
check these links for a better idea of what you may need...
monoblock lnb items - Get great deals on Consumer Electronics, Wholesale Job Lots items on eBay UK!
multi lnb holder items - Get great deals on Consumer Electronics items on eBay UK!Comment
astra @19East has a lot of spanish channels but they are NOT fta.Hispasat @30West has a few fta spanish channels.but you will either need a seperate dish or motor to get them as you wont get 28.2E & 30W on the same fixed dish.I"d read up a bit more or ask more questions about exactly what you want to do.Comment
